bebsy
Finicky
I've done the search to no avail to try and save some shame goes like this I put a new sender unit in when renewing fuel lines now the question is when I filled up with gas the warning light goes out as normal but the gauge just twitches a little and doesn't move at all but if I turn the ignition on and off now and then the gauge will jump to full or 3/4 full when it's turned off and when turned on again it drops back to zero, just miffed as all was fine before other than the old sender being bent out of shape like me right now and giving a way off reading which I adapted to but it worked at least, I was thinking a faulty earth is there a way I can check the meter... Cheers
