I want to use Avon cobras. What size tyres are recommended for front and rear. I have 13.5 inch shocks and have been told a 140 tire in front is the way to go for improved handling?
Put a Bridgestone E-Max on the rear. 240/55R16. Be aware with ABS you have to be a bit more careful than we pre-ABS folk. @1olbull has some good info on sizes that can and cannot be mixed. I use a 150/70VR17 on the front. Just as good as the 140 I had on prior to this.
Thank you!
Does the fact that I put on Hagon Nitros 240mm which is 3/4 inch longer than stock make a difference to the charts. I know the axle height remains unchanged but the loading on the front tyre will be heavier and wheelbase very slightly shortened right?
Axle height should increase at least .5" from 12.5" length stock. Add a Exedra Max with an extra .5 " and you get a full inch, most blokes would pay a fortune for an extra inch
Match with a 140 front tyre which (I am yet to do myself) and you should end up with a far sharper steering response than stock.
A tiny change in head rake and thus trail (on linear suspension) - and miniscule weight shift. The rear axle height being raised (and/or front dropped) does indeed load the forks especially under braking. An R3 in OEM condition actually nose dives very little. This is not too evident with stock suspension - but it is with sorted geometry.
The Exedra Max 240/55 R16 raises the rear axle up .5 inch and levels both axles. The 140/75R 17 front lowers the front axle .5 inch and decreases trail which quickens steering.
Use of taller shocks does not affect axle height, but it does affect (reduce) rake & trail, further quickening steering and reducing higher speed stability.
