Shimster1967
- Joined
- Feb 26, 2023
- Messages
- 13
- Ride
- Rocket roadster
I press the ignition button nothing happens all lights on as they should just nothing at all.
Tested the starter relay I have one pin with 12.9v 2 with nothing and one with .3v, when I press the ignition button it goes up to 4.5v all others stay the same.
If I put a 12v on the pin which has 0v it starts as it should so I’m guessing when I press ignition I should get the pin to go from .3v to 12v tand that triggers the relay to put the 12v to the pin I connect the temporary 12v too.
Any idea what the problem could be, I also notice the horn doesn’t work either
