Tripps
Retired superhero
- Joined
- Oct 9, 2010
- Messages
- 11,322
- Location
- Florida and NY
- Ride
- R3T,Sprintona,K1200GT, Blackbird,r/65 hack
So the bike is dead. I have a keyless ignition, when I approach the bike, it does everything it should, goes through the whole cycle, but hitting the start there's nothing, no click, anything, and battery is good, even topped it off.
So I noticed the 20a ignition fuse was reversed with the 15a next to it, when I switched them, I noticed that the one in the ignition slot was loose, like just laying there
Swapped them, then changed both, but I can feel, if you know what I mean, that nothing is gripping the tabs of the ignition switch at all, it's loose, wiggles around in the hole, tried several times reinserting it. I'm 90% sure this is the problem, is there any easy way to bypass that fuse to confirm this? Thanks in advance.
