OK here is the problem
The Rocket is not starting normally. Run through the usual sequence and I get no joy when I push the starter button, all else seems to initialise as per usual.
Like all experienced Rocket riders I have a new ignition set on hand and have plugged this in and it makes no difference.
It won’ t start with the stand down and the clutch in and I am not willing to risk trying to start it in gear in case she decides that this would be good for a laugh and fires up.
BUT
The bike will start in neutral without the clutch engaged if I hold the start button and then turn on the switch. It will also start with the clutch in if the start button is held in whilst the key is turned on.
Any ideas where to start?
BUT
