Bondysbike
Turbocharged
Ive read as many of the PCV auto tune threads as I could find and learned at lot from you all.
I’d like to ask two simple ( is there any such thing?) questions...
I have , with just the PCV on board got a map ( that was a canned map recommended by the PC folks as being very close to my set up) that has transformed the bike. It’s good performance wise and very little decel pop now and improved smoothness and overall performance.
Question: Now I’m really happy with how bike performs with this map in PCV. I have the bug though! Should I add the AT in the hope it will improve/ refine it further? Or should I avoid any risks and adopt the stance of ‘ if it ain’t broke don’t fix it’
Question: Once the AT installed , I understand that you run a few tanks through and accept the trims ( assuming all is well) to refine the PCV map. Once this is done do you then still leave the AT switched on...for ever? Or , once the trims have been accepted several times do you then switch the AT off.
Cannot quite grasp this. I’m not very technical but enjoy learning here and enjoying an ever improving Rocket.
Thanks...
2018 Roadster
DP outlaws
H&N triple air box delete
PCV map #M21-003-006
Auto tune ( not installed yesterday.)
Thanks...
2018 Roadster
DP outlaws
