TxRIIIRider
Well.. After bragging how my early Rocket has avoided most problems that have plaqued others with over 37,000 miles, I've now hit the dreaded idle problem over the past couple of days. GRRRRRRR.. The bike will barely idle at just above a fluctuating 550 - 600 RPM.
I'm going to try the 12 minute tune tonight after the bike cools down. This has worked in the past, but it's running a little bit different this time. Then I will unplug the PC-III (reloaded tune I was running already) and plug the O2 sensor back in and do the 12 minute tune again, and THEN.. I'll make an appointment with my dealer and get the latest Triumph TORs/Cat by-pass tune and have them check it out.
While hooked up to the laptop, I was looking at the throttle position settings, and the closed position readings continually fluctuated, which makes me think the TPS issue is here, but... we'll see..
