liquidsmile
- Joined
- Feb 6, 2009
- Messages
- 249
I thought I would share this with the people of this board, I did some research and found out that the headlight buckets from the Speed Triples are the same headlight buckets that the Rocket 3 has. So while looking around Customdynamics.com I ran across these.
Link Removed
If you scroll down the page, you will find the different designs that the sell in the 5 and 3/4 headlight size. I personally liked the "ICE" design, so that is what I went with.
Here is a link with them installed on a triple,
Link Removed
As you can see, they are big improvement over the stocker fogged over lights, and give a much cleaner look to your front end.
Here is a picture of them side by side
And here is a pic of one installed next to the stock light.
I will take some pictures with the camera tomorrow as these are taken with a camera phone and are not the best, but believe they are a huge improvement over stock in the looks department. I switched out the lights they send with the kit with a silverstar bulb of the same wattage the stock runs.
When I ordered they gave me a 5 percent off coupon code. I don't know if it can be used more than once or not, but give it a try.
COUPON CODE: jr2271
I would right up a how to, but it is pretty self explanatory. I did not use the foam rings that come with the kit, and I kept the stock headlight inner ring in place. Just as easy as changing your bulbs.
LS
Link Removed
Link Removed
COUPON CODE: jr2271
LS
