Did you check the gap before you set the tps to .6 the gap between the roller and cam should be .5mm after you retract the stepper motor. once it is you then set the tps to .6 volts. +-.2 volts then click ISCV and the motor should retract .12 volts +- .5 volts for total of .72 volts without the tolerances .
So it seems that my stepper control arm is rusted as hell and won't return to the fully open position without some 'motivation'. I'm gonna lube it up tonight. Does anyone know where I can order a new one?
