out of taff
.040 Over
One thing I noticed with my Rocket....Man is the motor warm! It feels like it wants to melt my right leg.
Is anyone else having this problem, has anyone solved to problem without putting asbestos chaps on?
My heat shields are glowing and I don't know what to do! It may be great in the winter but down south in Atlanta with 100 degrees F it is too warm.
Reply from TxRIIIRider
From the sounds of it, you are not running the right fuel map with your Jardines. It sounds like you are running way too lean.. This would cause the popping on decel.. and make your exhaust header a lot hotter than normal. Triumph's 'off-road' tune is still too lean for the Jardines. You need a DynoJet Power Commander with the appropriate map loaded.. or TuneECU or TuneBoy software to load a different tune to your bike's ECU.
I love my Jardines..They make the Rocket sound like the big bike that it is.. I have a DynoJet PC3 that I had tuned at a local dyno shop and my bike runs great. I do get a little popping on decel lately, but I believe my Jardine's baffles are about wore out. Thinking of going with Jardine's "quiet" baffles as a replacement. They are supposed to be a bit quieter and since they are not glass packs like the original baffles, they never wear out.
Originally Posted by TxRIIIRider Link Removed
Another welcome from Texas..
From the sounds of it, you are not running the right fuel map with your Jardines. It sounds like you are running way too lean.. This would cause the popping on decel.. and make your exhaust headera lot hotter than normal. Triumph's 'off-road' tune is still too lean for the Jardines. You need a DynoJet Power Commander with the appropriate map loaded.. or TuneECU or TuneBoy software to load a different tune to your bike's ECU.
Thanks TxRIIIRider.
But now what do I do....Think I can take it to my local Triumph dealer and have them fix it?
Too lean, too hot, that can't be good for the motor? I'm thinking.
Do you have any ideas, as I havn't the faintest idea of what I should do!
Thanks. Eric.
Thanks TxRIIIRider.
Thanks. Eric.
