doncuddy
soberdude
After a long ride--I inadvertantly left ignition switch on..key was off..sat for several hours. went out and wouldnt turn over at all..lights had dim glow--no instruments at all. pulled a boner and while hooking up cables from my truck--did it bass akwards..pos to neg..nothing...then checked fuses and found 30amp for battery blown...called dealer--said it was ok to charge til I replaced fuse. hooked up my slow charger and got a trouble light. took battery to autozone--said it was fully charged and not bad. got same light even after replacing fuse..all other fuses were good. I am at a loss..hoping I didnt torch something worse..can anyone tell me if there are other fuses to be checked? what else should be checked? really dont want to take it to the dealer--40 miles is closest...any ideas???hopefully a simple solution. don
