Stillserving
LET'S GO BRANDON
Looks like I'm going to have to change the head gasket on my '17 Roadster for an oil leak. Haven't looked too far into the job, but I know several of you have had the head off. Got any good tips/tricks, things I should be prepared for? Also any special tools I'm going to need? Trying to start gathering parts and supplies so I can knock this out in the next couple of weeks and figured any advice I can get from those that have done it would be nice.
Off the top of my head, I'm thinking in a nut shell:
pull motor
pull cam cover, pull front access for cam chain access
disconnect cams
pull head, replace gasket, reverse.
missing anything other the finer details?
Thanks
pull motor
disconnect cams
Thanks
