wsrvr
My R3 has been requiring more cranking than usual and I have to give it some throttle to get it to fire up after setting overnight. I need to nurse the throttle until it warms up, then it will hold a low speed idle.
I've reloaded the map using TuneECU, and had no error codes. The battery is fine, the TPS resets after remapping and at startup, fuel is clean and doesn't seem restricted once running. Engine starts readily and runs great after I get it running and it has a chance to warm up. I have 42,000 miles on the bike, and only now having this issue.
Oil usage is normal, fuel mileage is same as always, no fouled plugs.
Any ideas on what I should have inspected?
