Some (including myself) have had problems opening Tuneboy diagnostics after doing the latest download and install from the Tuneboy website. This fix offered by Wayne worked like a charm for me:
Is it Windows XP or Windows Vista ?
If your logon to XP does not have administrator rights then the install will not have worked correctly. If you have Vista then the install will not have worked correctly because Vista runs programs without administrator privilages even if you are in the administrators group.
What you need to do is this.
If you are using Vista.
Now, step 2 (Vista)
Step 2 (XP)
That is it, now the TuneBoy and TuneEdit icons on the desktop should work correctly and you will not have any blue screen woes (Vista).
Download the latest drivers from http://www.tuneboy.com.au/Support/TuneBoyDrivers.zip
Go into device manager on your machine and uninstall the TuneBoy Cable from the ports and USB drivers lists, make sure you select the tick box to delete the drivers from your PC.
Now unplug and plug the cable back in and install the drivers using the new files.
Now, step 2 (Vista)
click on the start orb, then all programs, then accessories.
right click on command prompt and select "Run as administrator"
When the command prompt appears do the following
Change to the tuneboy directory.
CD c:\program files\tuneboy\tuneboy
Now enter the following
regsvr32 tuneboycontrol.dll
a popup will tell you that it is registered
now enter the following
tuneboy /skinname=standard
Step 2 (XP)
logon as administrator.
click on the start , then all programs, then accessories.
You should now have the TuneBoy dash displayed in front of you.That is it, now the TuneBoy and TuneEdit icons on the desktop should work correctly and you will not have any blue screen woes (Vista).
