patrol21
.060 Over
- Joined
- May 15, 2013
- Messages
- 119
- Location
- Rochester NY
- Ride
- 2009 R3 RAMAIR Intake Full Jardine Exhaust Cor
Ok, Ive got a skip at some constant throttle. What I've done so far...when hard throttle it's fine.
Removed the stepper motor and maually tweeked the manual idle setting. It's perfect. Prior it was all over the place.
Balanced throttle bodies. Number one was out a bit.
Checked TPS at idle with Tune ECU. 6.0 on the nose
Checked wires to coils. Seems fine.
Dry gas/ Sea foam...as it almost seems like it's running lean as now and then at low throttle I'm getting a slight stutter and occasional slight backfire...like a fouled plug or lean TPS position
I have not cleaned out the in tank filter. Anyone have a clue how to do that? I assume empty gas and drop bottom plate in tank..is their a replacement seal that I need? I replaced plugs 5 k miles ago. Doubt it's a fouled plug but who knows.
I hate Gremlins
I hate Gremlins
