technoguppy
Recently I removed the CAT and installed some D&D 3:2 pipes. Then I had the bike serviced after for oil change, some new tires, and an overall inspection.
Went for a ride today, roughly 21C outside, while out riding, I noticed my machine was sputtering a little, so I thought, perhaps I will reset the CPU by letting it idle and it will adjust itself, after cycling on/off.
So upon shutting the machine off, I noticed a large puddle of fluid (I'm fairly certain it's coolant, smell and feel is appropriate) coming from where the CAT used to be (or just in front of it). Upon further inspection it was coming from a hose almost directly under the seat.
Do I have a problem or is it possible that the radiator warmed up and caused an overflow, and that is what I am seeing?
I will try again tomorrow to see if more fluid comes out, but for you guys in the UK and AUS, perhaps you could post overnight for me to read in the morning.
Thanks,
Thanks,
