Spartacus
I'm in the process of installing GiPro. I've followed the instructions so far; disconnect 2 pole plug on gear position connector and removed black/pink lead and inserted it into GiPro 2 pin lead. Then I disconnected pink lead from 3pin connector and installed it into GiPro 3 pin connector. I then plugged the bike 2 pin connectors back together and plugged GiPro harness to GiPro adapter as instructed. Next I connected the red positive GP lead to switched positive (PC 8) and also connected black negative GiPro lead to negative (PC 8).
Question not addressed in instruction is do I reconnect bike 3 pole harness like the the 2 pole bike harness?
When I power up the bike, the neutral light comes on (trans in neutral).
Next I went to program gear indicater. I pressed button to enter learning phase. Put bike in 1st gear. GiPro indicater flashing "1" as if learning 1st gear. Light keeps flashing and doesn't stop or move on to 2nd gear. I'm doing something wrong or missed a step. Any help out there?
