Funny things that excite me and increased fuel pressure
Discussion in 'Rocket Performance' started by Claviger, Oct 14, 2018.
Tags:
  1. Claviger
    Claviger HP Junkie extraordinaire
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
    '14 R3R, '02 Daytona 955i
    So just on a whim I was browsing through Jegs and found this, it's an amazing little device!
    59.5 PSI
    10 Micron Filter internally
    175GPH capacity
    So you can either replace all the items indicated with red, or use it as a second fine filter and just replace the stock triumph regulator. Hello more fuel, simple non-adjustable, small, should be tank safe as its all billet alu :)
    Holley 12-876: Billet Aluminum EFI Fuel Filter Regulator | JEGS
    You'll need a couple of barbs, which I've found here:
    Adapter, -8AN Male » 3/8" Barb, BLACK (ADF-484107): AN MALE » HOSE BARB ADAPTERS | Racetronix
    The only people who may need this are forced induced or big power NA guys looking to extend the useful power range of stock injectors or get better atomization using bigger injectors. Total cost is about $170, so roughly the same cost as buying a set of 60lb Deka IVs, but, for applications may be better suited.
    For those curious:
    Stock 330cc @ 43.5 and 390 @ 60
    Black Ops 550s @ 43.5 and 661 @ 60
    Tripps likes this.
  2. Claviger
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
  3. Claviger
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
    It all arrived:
    This setup provides an easier to source 5 micron fuel filter as well as increased fuel pressure. It’s the piece out of a corvette, so it will flow at least 450hp worth of fuel. Installation tomorrow with pics.
    Should turn my 550s into 660s, and improve atomization as well. Below is a pic next to a stock filter for size comparison:
    Steel and Big Mike like this.
  4. barbagris
    barbagris Mad Scientist
    9,176
    Featured Threads:
    53
    Media:
    85
    9,037
    823
    On the verge of insanity
    Ride:
    2009 R3-Standard - 1979 Guzzi V1000G5
    Hope the barbs don't snag somewhere. I can't see where they would - but
  5. Claviger
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
    It was almost a perfect fit, need to browse the Earl's catalogue and find a 180 tight radius board 6AN fitting. This will work but it's not ideal.
    Before:
    20181026_161316.jpg 20181026_161301.jpg 20181026_161255.jpg 20181026_161351.jpg 20181026_161344.jpg 20181026_161335.jpg 20181026_161320.jpg 20181026_161252.jpg 20181026_161247.jpg
    phar2slo likes this.
  6. Claviger
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
    After pics coming, I plumbed it wrong lol. Posting this here for anyone who may want to do the same in the future for some reason:
  7. Claviger
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
    There's certainly something to be said about barbed fittings on the housing itself, like the stock filter, instead of GMs quick disconnects in a tight space lol.
    The black pad on the regulator filter should be fine in the tank, time will tell when I yank it to put the 150 radius in instead of having the output hose all doing compound curves.
    For the record, use 5/16ths not 3/8ths...
  8. Claviger
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
  9. barbagris
    9,176
    Featured Threads:
    53
    Media:
    85
    9,037
    823
    Ride:
    Ah the joys of R&D
    Claviger likes this.
  10. Claviger
    5,111
    Featured Threads:
    118
    Media:
    69
    6,356
    823
    Olympia Washington
    Ride:
    Ok FINALLY I got something done, it takes minor tweaking of things but not hard really. This should support 250-260 whp NA safely with stock injectors and a Walbro pump.
    20181106_191637.jpg 20181106_191632.jpg 20181106_191628.jpg 20181106_191651.jpg 20181106_191648.jpg 20181106_191640.jpg
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
