DEcosse
If it's no Scottish it's CRAP!
For those of you with Fuelbot - or intending to get one - do you wear Polarized sunglasses?
It was source of frustration for me that with my sunglasses on, the FuelBot display was completely BLACK!
It's because the LCD Display is polarized itself and the one on top of the other cancels all the visible light.
I found that if I photographed this through my Sunglass lens, in normal orientation the screen was black, but if I rotated the lens 90 deg, it was perfect again
I discussed this with Dave and the actual display itself (not the lens on the enclosure) is polarized which didn't leave much to do there
I was almost resigned to getting some non-Polarized lenses - but then you lose the very advantage of the Polarization when viewing everything OTHER than the Fuelbot!
I did some internet searching on the subject and via this article came across this product
Decided to give it a go - here are the results:
Initial display, no filter shield and no sunglasses
Looking through the Polarized lens (the image actually flatters the reality - it is totally black to the eye when viewed through sunglasses worn normally)
Here is another pic I took before I ordered the filter material - it shows up the problem much more acutely
This is with the Dayvue applied through same sunglass lens
This is with Dayvue applied, view without glasses
Looking at it with sunglasses on, you can definitely see the display now vs black before, without the new filter.
It's not quite perfect for me, but I think that has more to do with my mono-vision and the focal length to the display (I have one eye corrected for distance (lasik) and the other not; So the digits are not as sharp as they might be, but they are legible now)
I took the film initially and tried it in different orientations to see which gave best transmission
(it's not ideal because the filter has two layers of peel-off pink plastic on either side so that by itself reduces the light)
But I could see that 45 deg was better than either of the 90 deg planes
So that is what I ended up cutting to size and applying
Interesting stuff!
p.s. you can see the effect yourself if you have two pairs of sunglasses - put one over the display normally and screen goes black; take a second pair and put that over screen at 90 deg; then look again through your glasses. The filter works the same way - it re-orientates the light by refraction that then makes it visible through your Polarized lenses
Interesting stuff!
