Mark Rieger
Standard Bore
- Joined
- Apr 5, 2016
- Messages
- 9
Ok so my 2009 Triumph Rocket 3 roadster had been of the road in the garage for years due to it being stuck in third gear. Did not have the money to fix it finally took it to be repaired. So bolt replacedwith lock tight. No spark at the plugs ECU not working replaced that. Still not running only on tick over injectors removed and professionally cleaned and tested.
Fuel injectors ok
Fuel pump pressure is good but still will only run on tick over.
Seems there is a weak fuel mixture.
HELP Any ideas how to resolve this issue or what the problem could be ??
