High Guy's
Have just rebuilt my master cylinder but can't get them bleed. Have tried the old fashioned bleeding with the help of her indoors and also vacuum bleeding but nothing. I took the calipers off and fired the air line in to see if the pistons were siezed. A couple were sticky but all ok and still nothing. I noticed in the the master cylinder that when you press the brake lever and release the piston never comes back further than the small hole, you never it see come back past the larger hole!! is this correct or should it come back far enough to push fluid down the brake lines? have I screwed up rebuilding the master cylinder?
Cheers
Gary
Cheers
Gary
