EasTexRIII
I'm doing the change over to Progressive springs. So I have them apart, new 7W oil, new seals in. the manual says to put oil level at 89 mm from upper edge of fork tube, with fork fully compressed. OR, Alternatively just put in 667 cc's of fluid. In my feeble mind, since the forks were completely drained & all fluid pumped out of the dampers it would be easiest to just add the 667 cc's. Ok - Then it says add the oil & pump fork assy & damper several times to expel air, let settle & measure.
Now, they want you to measure level to 89 mm with fork full compressed.
Here's where I'm confused... The 667 cc's has the level too high after pumping up & time to settle, no problem. Pour a little out. Now, I'm trying to get to the 89 mm. Do they want you to measure with the fork tubes compressed AND the damper rod compressed into the "all the way down" position? or fork tubes compressed AND damper rod pulled out to the "all the way out" position?
The picture in the manual looks like the damper rod is pulled out to the "all the way out" position, which brings the fluid level down quit a few mm's from when the damper rod is in the down, or in position - so it makes me assume that the correct way to the 89 mm measurement is with the fork tubes compressed but the damper rod up, or out..... Is that correct??????
Thanks,
Clint
Thanks,
Clint
