- Joined
- Sep 8, 2006
- Messages
- 1,371
- Location
- Fredericksburg, Virginia
- Ride
- 2005 Rocket 3/2014 Moto Guzzi Touring
Just FYI for anyone who has noticed a slight anti-freeze smell while riding but never found a leak. Today I installed a K&N crank case filter (#62-1340) since I run an under the tank K&N set up. (Brian is right about the install, loosen the air filter box for the additional room unless you have hands like an anorexic teenage girl.) During the procedure I noticed a little antifreeze seepage around what appears to be a freeze plug located on the rear of the exhaust side of the engine. I sealed the plug with a little Marine Tech after a conservative tighten and will probably back it out and coat it with Teflon tape doing the next anti-freeze change. Just FYI in case anyone else has had this problem. Here is a bad shot of the plug.
