Stillserving
LET'S GO BRANDON
Can someone with the fork spring tool take some measurements for me? I've got access to plenty of 6061 AL thick wall pipe and was just going to cut a piece and drill/tap two holes. I would like to know what the inside diameter the circle portion is, so I can select the right size piece. Also, I need know what size the holes are in the spacer or what size the actual bolt portion of the tool is so I can get the right size bolts. Figure, the pipe scraps are free and I'll only be out the cost of two bolts (if I don't have the right size laying around). If it doesn't work out I can always buy the actual tool, but I like playing around making things. Thanks.
