Fork seal. Getting correct fluid capacity?
Discussion in 'General Tech Talk' started by GreasyGeorge, Jul 12, 2019.
Tags:
  1. GreasyGeorge
    GreasyGeorge .020 Over
    Country:
    United States
    27
    Featured Threads:
    3
    59
    23
    Boston, ma.
    Ride:
    2011 triumph rocket roadster
    Hi everyone I’ve replaced my fork seals on my 11 roadster. I haven’t disassembled the spring though. I know the manuel has you take the spring apart to accurately measure the amount of new fork oil. One fork wasn’t leaking so I let It drain overnight to try to get a accurate oil measurement that way, and then fill both forks with that amount. I pumped the spring cartridge to get as much oil out as possible. Has anyone done it this way? I guess it’s a bit of a shortcut to not disassemble the spring but am I setting myself up for failure?
    Thanks in advance
    629FED5D-47D8-4B29-995D-F5DB2710E139.jpeg DB0004EE-490F-41BD-988A-8B5A01081D30.jpeg
  2. idk
    idk Living Legend
    4,693
    Featured Threads:
    12
    6,276
    823
    Maryland
    Ride:
    Royal Enfield Bullet
    I've usually found that the quick way takes longer.
  3. GreasyGeorge
    Country:
    United States
    27
    Featured Threads:
    3
    59
    23
    Boston, ma.
    Ride:
    Yes there is definitely some truth to that. Just thinking if I’ve completely drained them overnight then should be good to refill with 667cc of oil. Maybe 666 to account for a bit of residual
    TURBO200R4 likes this.
  4. 1K9
    1K9 Big Cruisers 4 Me
    Country:
    United States
    3,356
    Featured Threads:
    2
    Media:
    16
    3,819
    823
    Clear Lake / Houston, Texas
    Ride:
    2007 Rocket III
    I'm paying for that service/repair of my sloppy tubes :(
  5. Steel
    Steel Resident Coonass
    6,818
    Featured Threads:
    26
    Media:
    9
    18,629
    823
    Cut Off, LA
    Ride:
    2012 Roadster & 2006 Classic
    If they are empty it will take 667 cc in each fork tube.
    Joesmoe likes this.
  6. GreasyGeorge
    Country:
    United States
    27
    Featured Threads:
    3
    59
    23
    Boston, ma.
    Ride:
    That’s what I’m saying. So why bother taking the spring apart just to drain and fill the forks?
  7. Paul Bryant
    Paul Bryant Living Legend
    Country:
    New Zealand
    2,794
    Featured Threads:
    45
    6,028
    823
    Hamilton. New Zealand
    Ride:
    2006 Rocket
    Yea' a five minute job takes at least 30 minutes :roll::roll::roll:
  8. sonny
    sonny Living Legend
    7,080
    Featured Threads:
    121
    12,846
    823
    Henryetta Oklahoma
    Ride:
    rocket three x
    I took everything apart. CLEANED everything. A lot of nasty stuff got cleaned and removed when i upgraded to progressive springs. Made all the proper adjustments with the tools that Truimph recommends for the job. Even the silly tube thing that looks like a syringe was used. Three tools and adjustments made no issues since then. Followed the manual 100% percent. Just my two cents worth.
  9. Idaho Red Rocket 3
    Idaho Red Rocket 3 Living Legend
    4,306
    Featured Threads:
    42
    4,537
    823
    Nampa, Idaho
    Ride:
    2006 R3 Standard Bagger w/Fairing
    While you have it apart get a set of Progressive front fork springs. Up grade the fork oil to 7 weight.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
