Blackthou,
you really have to loose that term "Back pressure" it is the most over used and inaccurate term possible.
Back pressure is what you get when you put your finger over the end of a running hose, not at all good for getting a lot of water out of the hose.
A hint about exhaust systems, when we are talking about performance, we really are not dealing with exhaust gases but sound, or more to the point shock waves.
The shock wave travels the length of the pipe where it hits atmosphere, (end of pipe) reverses, heads back up the tube, hits the closed exhaust valve, reverses again, if all is correct this happens at just the right time when the exhaust valve is opening so as to "draw" that next spent charge out.
The diameter and length of the pipe, along with the cams used and compression ratio all conspire to make this work
at any given RPM
All formulae for exhaust design ask what RPM you want the power at.
Mr Hunt, when you have a "collected" system each pulse draws the next one out as opposed to a single pipe per cylinder where (basically) the gas/shock wave just falls out the end.
There is of coarse a lot more to it than just this, but I hope this gives you some understanding.
