Rogiecrockett
I was doing the 10K oil change yesterday morning and while everything was off I thought i would drain the final drive oil and replace. I know it is a 20K change but it is not expensive, I have the oil and I wanted to spend time working on the bike so 'what the heck'.
After draining the oil I put the drain plug back in and tightened with a socket. I backed off and then put a torque wrench on it. The torque wrench kept going so I stopped. I put the socket back on and tried to remove the drain plug but it would not come out. It will not tighten and will not loosen - it just spins.
The screw appeared to go in OK and did not feel cross threaded. When I tried to remove it with the socket it turns easily then gets slightly tight and then easy again.
I filled the drive reservoir up with gear oil and let it set overnight. There are no leaks.
I feel like it may be stripped but I am not sure. I tried to grab it with a pliers to apply force on it out while unscrewing it. Due to the way the plug sits in the recess it is hard to get a good grip on it.
Any ideas?
Thanks,
Dave.
Any ideas?
Thanks,
Dave.
