Exhaust clamp torque specs?
Protonhound
Turbocharged
Calaveras County, California
2023 Rocket 3R
I have tightened the muffler clamps on my new Vandemon exhaust a few times since installing it. They do not provide any instructions whatsoever and have not yet responded to my email asking this. I'm talking about the 2 clamps securing the pipe assembly to each muffler. The system is made out of titanium and the clamps are likely steel. What torque value should I be aiming for?
"Goudentite" Seriously, I remember trying to use the torque spec on my Roadster and ended up breaking the bolt. This may be one of those rare cases where I'd go by feel. I'd recommend using some exhaust gasket seal though.
The spec for the cat box clamps is 11 Nm. That's a good starting point. If it leaks add another 5 Nm, wash rinse repeat until no more leaking.
"Goudentite" worked and it's been staying so. If I tightened it any more I'd probably do damage to the clamp.
Just as an FYI, Goudentite is equivalent to 3 ugga duggas . . . The correlation can be found in the beezdic to gnatswhisker chart.
You don't want to go more than 2 ugga duggas over that because that could be the equivalent of 1 Oof-****k. You'll find an Oof-****k is the same in metric and imperial
