I'm noticing a consistent stutter in the motor when I accelerate starting around 3200 rpms. Seems like i feel it when I do a light acceleration vs hard acceleration. It feels like a misfire or something similar. Anyone have any experience with this?
Check the low tension leads on the # 2 and #3 are easy #1 up in the neck a little harder to get at . clean and give the spade connectors a squeeze to tighten them up so they do not give intermittent connections. see picture below which is # 2 coil
Yep, just had this yesterday. By the time I got home I only had two cylinders. I was guessing bad coil pack, but after reading here, wiggling the low tension wires fixed it immediately.
