Jeremy
.060 Over
First off, I appreciate everyones help on here. I am learning so much about this new machine.
I posted awhile back that I was having trouble finding neutral. The culprit was simple, the clutch cable was not in tolerance. not an issue now.
Then I posted while I was on a ride that the engine light came on and i was still able to get it into neutrual with no issue, but the light only comes on 50% of the time. When I got home, I pulled it up and found that it was the gear position sensor. I cancelled the code and all has been good for about a month. Now riding to work, all was fine, I pulled over into a parking lot as my wife was calling me and it was odd that she would call me twice when she knew i was on the bike. I put it in neutral, light did not come on, and i called her back quick. Then I put the bike in gear and went about my ride to work. At some point I looked down and noticed that the engine light is on again. I will not be able to check the code, but assume that it is the position sensor code again that i need to clear. I leave in the morning for Algona, IA rally.
Is there a write-up on how to fix this easily or something? I want to be clear on what to do and what NOT to do with the sensor. I am not sure if it comes all the way off or if that will cause an issue? does it just need cleaned up? or is it something that i can ignore and will be more of an annoyance.
Also, does this dictate to the computer what gear it thinks i am in and what it then would think that the fuel mixture should be and maybe it will be off?
Everything about the bike seems to work great other than that.
Thanks,
Jeremy
Thanks,
Jeremy
