Namikuz
Rev'em high, Rev'em HARD!!!
Well I went to Houston Texas to pick up the Rocket....fixed the #1 misfire , vacuum hose to map disconnected, fixed the wiring for idle circuit, and had a great ride home....mostly, around 900-ISH miles, I developed a , for a lack of a better description, a pinion or U-joint vibration(I made it home to Slaterville, (Northern Utah). On throttle, rough, part throttle, hear and feel something, off throttle rumbling and a bit rough.I checked with a stethoscope, It's coming from the shaft tube area, not in the bevel drive, no noise from the rear engine case, pulled the wheel, no spring in the shaft end. How important is that spring? Will the shaft move back enough to cause the u-joint to rub the tube? ANY ONE KNOW???
Yes I am going to order the spring...(if I can get one.)
