Ey up people...
About a 1000 miles ago I started getting the old click and no cranking from the starter... read up on here and bought the solenoid rebuild kit off eblag and everything was fine and dandy..... well the dam thing has started doing it again.. fine when cold but after riding and letting it cool for around an hour all you get is click click… its deffoo the solenoid clicking again and when it does spin the motor it whips it round and starts on the button... meanwhile I did see a tip on here about putting it in gear n rock it back and forth then start it which works every time… but how does this work if the starter is not engaged in the first place??? I can understand it if starter was stuck in the engaged position but its not...so how does the rocking movement in gear enable it to start when I get the click noise..? am I missing summat simple here??? And as this appears to work does the fault lie elsewhere and not the starter??? Confused..
