Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
Now that Mufasa is making proper power I’ve been thinking back to last year and how racing went.
I watched a lot of videos and read a lot of instruction by the likes of Ricky Gadson and his brother.
Basically they’re method is get rolling get the clutch out and get to WOT as quickly as possible. If you slomo some of his ZX-14 launches you’ll see him full throttle and clutch out in 1 bike length or less.
Despite all my mental alarms screaming NO NO NO I was able to force myself to got full open well before the tree, it’s terrifying lol. I tried this method last year, it resulted in consistent times and traps, but the bike would jumped off the line and then spin up the rear as soon as it hit 4000 RPM if I remember correctly. So I’d either short shift or slightly back off and ride it out. It wasn’t pulling up the front, just spinning hard. Track had a lot of VHT but it was cold, around 50f and overcast.
Any experienced drag racers out there have any suggestions?
Setup was full loose compression damping rear, tight rebound damping rear to slow the weight transfer back to the front. Avon Cobra at 36 PSI. I now weight 215lb with gear, bikes a touch over 700 fueled. The pressure was high for drags but I was nervous about going low pressure when trapping 135.xx.
Really want to get under 9.5s and should trap at 150 now, I think it’s very possible for the bike if I can cut a good 60.
