Doesn't anyone know what the correct part number is?
irieco
.040 Over
La Quinta, California
R3 Tribal Classic
I'm at a bit of a loss with which sealing washer I need to order. They are the ones that are on the banjo bolt under the tank. Different ordering sites state different part numbers.
T3550573, T3550128, T3550123, T3558989...
I think it's the T3550573 but I just want to be sure.
ozrider
2008 Standard
Brisbane, Austraila
2008 Standard
T3550573 Part Name: Washer, BANJO, M12 X 1.5 Triumph Banjo Washer, M12 (T3550573) is used in Fuel Pump & Filter assembly for Triumph Rocket III,
T3550123, T3558989 are sump plug washers 16mm and 14mm ID
Just go to a bolt shop and get 12mm alloy washers
Gerald
Turbocharged
Lou. Ky
05 Rocket 3
Takes two banjo washers/ sealing washers m12 #T3550128
