Jay
E pluribus unum
- Joined
- Jan 3, 2019
- Messages
- 814
- Location
- California, USA
- Ride
- 2023 Rocket 3 GT (Ego), 2021 Zero SR/S (Earth)
I made the bonehead move of touching my rubber tank supports (part number T2400478)...they looked a little loose, but I should have left well enough alone. Anyway, I ripped them off and needed a quick fix. I found that the rubber nuts used for sport bike windshields make a great solution for attaching the rubber supports in the blind holes of the frame. Here are the hardware items I used. Note that if you can get a rubber nut that is tapered it will fit the blind hold in the frame easier. I did have to use a rubber mallet to seat it though.
#8-32 x 14/32 Expansion Nut
Corresponding countersunk screw
I also tried #10-24 x 9/16 expansion nut that was close and can work if you have variance in your hole diameter.
Hope this helps.
Hope this helps.
