I am finding a lot less resistance in the return of my gear lever , gearbox is tight , no shift or neutral issues . Is it the beginning of the end for the detent spring or am I just being paranoid ?
Thank you ! I suspected it would be reachable . The spring has lost a lot of its tension , it still resists in both directions but certainly not tight . I have never known this to happen , I don't think it's broken Just gone slack somehow ?
Yes , I have moved to silkolene and the gearbox is noticeably slicker and the clunk into first from neutral has all but vanished ! The issue is definitely in the return spring tho . The sitting tension of the gear lever is certainly less , which causes the lever to bounce slightly when riding over bumps !
The front cover gasket costs bugger all and you won't lose much oil so its a small price to pay to pull the cover make sure nothing more dramatic/catastrophic is about to occur...
Something inside me says , that is what I should do . As I mentioned before , I have never known a return spring to fail before .
I don't think it's broken because there is a small amount of tension . The detent arm is locking firmly into the pawl , it's just the slack in the lever once it has !
