A little story regarding my first ride after installing the D&D's. I realized that fuel enrichment (via Tuneboy) would be necessary after installing my D&D's, but couldn't resist taking the bike for a quick spin after bolting on the new pipes and liking the sound.
After a quick run down the highway and about 5 miles, I pulled back into the garage and the D&D's were smoking. Apparently, I had caught the insulating material within the pipes on fire from the original lean factory tune along with the added airflow from the D&D's. The Rocket's a good test for the chrome and pipe's quality to determine if discoloration occurs and the D&D's hold up fine. In addition, you'll shed quite a bit of weight with the D&D's and they will increase the A in A/F equation.
The D&D's present no interference with the factory saddlebags or Rivco passenger floorboards w/extenders. Again, the only drawback is the naked appearance on the left side.
As far as performance, D&D’s + K&N’s + Tuneboy and you’re looking at perhaps… another 10-12% potential. Without significant internal modifications… piston, rod, crank, cams, cylinder heads that are not readily available, most have looked at a forced induction system in order to get significant power gains from the stock Rocket engine. Good thing it starts out with 140hp!
