dbutton12
.060 Over
My 08 has (had) corrosion under the clear coat on the lower fork tubes. I did finally find a product that will remove the clear coat without damage to the aluminum. The product is Martin Senour Paints #6802. However, it will not even begin to work until you heat both the fork tube and the remover solution....if you try it at room temps it just sits there. I heated the (caustic) solution by placing it in a pail of hot water (about 120 degrees) and used a heat lamp to heat up each fork tube to about the same temp. Do not get your face/eyes over the solution as you paint it on or you WILL be in pain.
After removing the clear I wet sanded the aluminum with 600 wet/dry paper and polished using a Dupont polishing compound on a small foam power polish pad. (can find those at Harbor Freight)
The final result came out great and I have NO intention of putting clear back on,,,,the polished aluminum looks great and all I have to do is give it a quick polish in the spring. I was tired of people saying "hey get the bugs off those fork tubes" because that is exactly what it looked like.
