Corbin Motorcycle Seats, Saddles, and Accessories Online
www.corbin.com
Simply install the Corbin bracket onto your fender with the included bolts. This provides the mounting points needed to mount the Dual Touring saddle. We recommend the use of Loctite or other threadlock compound and torque these bolts to 8 ft lbs. If using a heated model, you will also need to connect the wiring pigtail to your fusebo
