Coolant or Oil Temp Gauge Recommendation
Hubguru
It's Throttle Time!
Flower Mound, TX
2017 Rocket III Roadster, 2012 Kopavi V8 Trike
Starmanut
Turbocharged
Spanish Fork, UT
2010 Rocket III Touring
A few of us have some cheepos that replace the oil cap. I got one for around $15. But you can't see the temp when riding. I use the OEM cap anyway, unless I want to check the temperature from time to time.
barbagris
Mad Scientist
On the verge of insanity
2009 R3-Standard - 1979 Guzzi V1000G5
I have a little 48mm round analogue dial Koso fitted - At the moment I have it monitoring AIT - Was dirt cheap (18€) on Amazon.
leatal
Turbocharged
Dothan, Alabama
2014 Roadster
I'm partial to the digital display provided by the PC-V eco system. If you've already got a PC-V, the POD-300 can provide a coolant temp guage, among other things.
Running with the POD-300 set up to monitor the water temperature, engine RPM, throttle position, speedometer, fuel/air ratio. It also has three colored led lights (green, amber, red) which can be configured to turn on for any configuration you want. I have mine set up as a shift light. Green 2K-5K RPM, amber 5K-6K RPM, red 6K RPM and above. The system is cool as you have three screen display choices (you can switch between the screens) and can have the screens display anything the PC5 can read. Really a fun system to play with. Unless you add transducers, I don't think you can monitor the oil system (temperature or pressure).
Claviger
Aspiring Student
Olympia Washington
'14 R3R, '02 Daytona 955i
You're correct a new sensor would need adding for oil temp, and you'd be limited to oil or water not both, because of the number of devices PC-V can handle.
Hubguru
It's Throttle Time!
Flower Mound, TX
I'm more of a digital readout guy, but really like the aesthetics of the VDO gauges, very clean look and matches great with the stock units. Interested in your build notes.
Thanks for listing other options as well, all great input folks.
JR
barbagris
Mad Scientist
The Vision Chrome Series are close in style to the factory gauges (also made by VDO) and are IP64 rated as well.
If you don't see water often - fair enough. But ime IP67 is the minimum for Bike instruments. And IP69 (jetwashproof) should be the aim.
Thread starter Similar threads Forum Replies Date
Wadejesu Coolant Temp 2.5 Litre Rockets 1
El Bruto Coolant temp?? General Tech Talk 2
RocketJockey Replacing Coolant Temp sensor Common Issues 2
Jeremy COOLANT General Tech Talk 5
Darron1117 Found coolant leak? General Tech Talk 1
Similar threads
AdBlock Detected
I've Disabled AdBlock
