ROCKETOUR
.060 Over
I have version 1.7.7 and on the TuneEcu website it says:
(I have a 2008 R3T)
Reset Adaption, prior to version 1.9.6, Reset TPS (Keihin ECU only), Triumph only
These option are not applicable for the Sagem models.
Process will be launched in the test window (Reset Adaption).
<Menu> ECU--- Reset Adaption
After each download, a Adaption reset is needed.
1. Turn the ignition off and back on again.
2. Wait 10 seconds and turn the ignition off again.
3. Turn the ignition on. Wait until TuneECU has connected automatically and select Reset Adaption
from the ECU menu.
4. Start the engine and let it idle until the TPS light in the status bar becomes green – around 15 to 20
minutes, at this process, don't touch the throttle.
If the TPS light doesn't turn green after twenty minutes, don't worry and turn the engine off anyway as sometimes it doesn't trigger, and in our experience the job is done anyway.
Is everybody doing this? I went through a loading process with PowerTripp about 2 years ago and I don't remember going through this on/off/on routine with the switch. The comptuer is hooked up the whole time? Then at step 3 a box with "reset adaptation" will light up? And after all this you still do the 12 minute tune afterwards? What will happen if you don't reset adaptives?
I really want to load Wayne's tune but I'm affraid of mucking it up. Can anybody clarify/assist? Thanks.
(I have a 2008 R3T)
from the ECU menu.
