RacerX74
06 R3
OK after about 600 miles I have now decided to replace the clutch
its noisy but only sometimes ,judders when cold but only sometimes I have trouble engaging 1st from a standstill when hot and I almost never get a smooth shift between 1st and 2nd going up ..the movement on the lever between on and off is about 4mm no matter how much I fiddle with the adjuster
I'm going to replace the cable to and change the oil as well
Any major pit falls of clutch replacement I should avoid ?
Is there any brand of clutch better than another ..would the basket / actuator need replacing ?
as much as I'm loving the old girl the clutch is letting the side down
20k 06 R3
any advice would be appreciated
cheers
20k 06 R3
cheers
