Clutch switch shenanigans...
Discussion in 'General Tech Talk' started by Jallen3.14, Jul 8, 2019.
Tags:
  1. Jallen3.14
    Jallen3.14 Supercharged
    Country:
    United States
    304
    Featured Threads:
    6
    595
    103
    Kansas City
    Ride:
    05 Rocket III
    I'm starting to have issues with the clutch switch. Is there an established cleaning procedure to perform?
    If I replace it, since it's a $106 part (you could replace just the $6 switch component itself on my Suzuki </gripe>), is the switch portion of it compatible with any of the later models with the flash to pass switch? or would I need to replace the whole **** assembly?
    I'm hoping a good cleaning will sort it out.
  2. motolink
    motolink Nitrous
    Country:
    Australia
    1,317
    Featured Threads:
    61
    783
    223
    Brisbane South, Australia
    Ride:
    2011 Roadster and 2001 Bonneville
    I had a problem with my clutch switch, I remove it from the perch, pulled the rubber cover back as far as I could, washed the switch in a mixture of vinegar & salt to remove all corrosion then washed the switch in bicarbonate of soda, gave it a good blow out with the air hose, the switch work great, then pushed in as much electrical grease as I could into the switch and refitted. No more problems.
  3. DaRiz
    DaRiz If I give a chit....You'll know
    Country:
    United States
    45
    Media:
    5
    63
    28
    Pea Ridge Arkansas
    Ride:
    2006 Rocket III Classic
    WD 40 worked for me when it happened out on the road.
    dandiego, Starmanut and TURBO200R4 like this.
  4. BigNorm
    BigNorm Boobie Inspector
    Country:
    United States
    3,406
    Featured Threads:
    30
    4,354
    823
    Minden, NV, USA
    Ride:
    2014 Rocket 3 Touring
    I cut the switch out and soldered the wires.
    dandiego likes this.
  5. Jallen3.14
    Country:
    United States
    304
    Featured Threads:
    6
    595
    103
    Kansas City
    Ride:
    05 Rocket III
    Thanks guys, I'll take some contact cleaner to it. I don't want to bypass it as I still plan to get a DeCosse ignition when the piggy bank gets full enough...
    dandiego, TURBO200R4 and Starmanut like this.
  6. motolink
    motolink Nitrous
    Country:
    Australia
    1,317
    Featured Threads:
    61
    783
    223
    Ride:
    Jellen, how did you get after spraying the switch with contact cleaner.
  7. Tripps
    Tripps Retired superhero
    Country:
    United States
    5,468
    Featured Threads:
    33
    8,534
    823
    Florida and NY
    Ride:
    R3T,Sprintona,K1200GT, Blackbird
    Don't spray wd 40 in it, whatever you do, it's not for that
  8. Jallen3.14
    Country:
    United States
    304
    Featured Threads:
    6
    595
    103
    Kansas City
    Ride:
    05 Rocket III
    Well, ummm... see, the thing is... it's only been a little over a month - barely seven weeks since that post and I've yet to crack it open. Every time I go out to the garage, the road beckons and I keep wiggling the lever to start.
    Soon. I'll get on it soon.
    Hopefully before it breaks completely...
    Joesmoe likes this.
  9. sonny
    sonny Living Legend
    6,725
    Featured Threads:
    116
    11,946
    823
    Henryetta Oklahoma
    Ride:
    rocket three x
    Replaced mine during last upgrade IMG_0724.JPG Would work for awhile after cleaning but would not last. No issues with starting the bike since replacing.
    TURBO200R4 likes this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
