albertaduke
former airline pilot without the big bucks
standard R3 2006
i disconnected the clutch cable from the bell crank arm at the bottom as I replaced the clutch housing on the handle bar and the cable had to be removed from the handle then when I reconnected the cable to the bell crank and the handle bar THERE IS NO TENSION ANYMORE ??? from the bell crank.
did something snapped inside or did i do something wrong by removing the bell crank from the shaft nothing happened when removing so I cannot figure out what went wrong and I do not want to open the clutch housing the manual does not help much either !! somebody can think of what is wrong....
