I correctly diagnosed a broken detent spring thanks to some knowledgeable people on this forum. (thanks warp 9.9) . I pulled the front cover off and found both pieces of the detent spring. I pulled the clutch apart and carefully laid everything down on newspaper exactly as it came apart. Replaced the spring and put it all back together as it came apart. I oiled the fiber plates as I put them back in. Put the clutch cover and radiator back on, adjusted the clutch cable, congradulated myself on a job well done and had a few adult beverages. Today I replaced the quart of oil that came out and filled the radiator. Started her up and dropped it in gear and she went clunk and stalled the motor. I took up some slack in the clutch cable with the same result. I kept playing with the cable adjustment until I knew it was too tight just trying to get the clutch to disengage but it kept stalling the motor. The clutch feels normal, but it isn't releasing. Not really looking forward to pulling it all apart again and don't know what I would be looking for anyway as I thought I put it together right. Any ideas?
