roame
I developed an occasional shifting problem, primarily hitting neutral. I had to be certain I had the lever fully pulled. I tried adjusting the clutch which solved the shifting problem but then my clutch wanted to slip when accelerating. So all that said. I removed the pivot pin and pulled out the clutch lever from the handlebar to have a look.
The pivot pin is about 6mm in diameter while the hole in the lever appears to be about 10mm. I'm wondering if there is a bushing that should be taking up all that slack. I have a service manual of sorts, but the exploded view doesn't show any bushing. Have any of you looked at this. I've put a nylon bushing in to see what results but haven't been out to test yet. The weathers not right and I don't want to be in a rush when I check it out.
