the two wire connector u found is probably for the cigarette lighter socket that would go into the little plastic cover on the left side.
if u disconnected the sensor to see what happens (ing on unplug the sensor light should go off. connecter on light on start motor light should go off if it don't go out u have a bad sensor or oil pressure two low.
i think that there has been a couple with bad sensors. hth
