triroketman
Mount Carmel Illinois
Hey Guys, I just purchased the Triumph cat bypass option. There were no instructions or anything with it. Just how do you install it? Is it a big job?
Any help would be appreciated.
Thanks.
Dave
06 Classic R&W
Pig9r
Kansas City, MO USA
There are no instructions for it. Basically remove the cat box and replace with the bypass. There are wire mesh gaskets on the connections that should be reused if they come off clean or replaced if they don't.
dragline708
Brandon Fl
Note :
Also if I remember right its been a good while ago now,
since I did mine
The long bolt the goes through a bracket that hold the cat box on .
When you un screw that .. its un bolted after a bit , but you have to apply
a little back pressure ( pulling on head of bolt ) and turning , because
it spins in rubber gommet , to get it out
wayne
OUsooner
Standard Bore
Edmond, OK
You have probably long since done this mod. However, don't forget to use the rubber spacers that are on the cat box. You will need to remove, they are very tight I found a little W-D 40 will get them loose. Then attach to the bypass pipe. Other than that don't forget to re-map. Have fun!
AdBlock Detected
I've Disabled AdBlock
