scot in exile
When moving the air keeps the heat away from you, I wonder if the ones who complain about the heat have any kind of fairing or wind deflectors?
One point Carpenter should bring up with the exhaust maker is as you can see in the second picture if the hole for the spring was on the other side of the nut it would stop it rubbing on the pipe I will drill a hole so I can move it.k
When I first fitted the pipes I put for a better word condoms on the springs now I have removed five of the six condoms as they were clear of the pipes and the last one will be gone once I drill the hole.
