Can Cam Timing be off from Top Dead Center?
Discussion in 'General Tech Talk' started by GaryB, Jan 12, 2020.
  1. GaryB
    GaryB .020 Over
    Country:
    United States
    11
    1
    3
    Chandler, AZ
    Ride:
    2005 Rocket III
    I can usually find answers to my issues but this one I can't seem to find anywhere. So here is my first question post.
    I have a 2005 Rocket III and the motor is in the frame and I would prefer not to remove the front cover.
    My issue is when setting cam timing I can't get all of the chain slack on the adjuster side so after install when I turn the crankshaft the adjuster continues to adjust and then the cams are not aligned with TDC. I have tried several times to turn the crankshaft away from TDC so that when the slack is taken up I am closer to TDC but the below picture is the best I have been able to do. The picture shows where the cams are when at TDC. The cams are aligned to each other but are a little out from TDC.
    Is this acceptable?
    Any one else had this issue and found a way to solve it?
    Is there some trick to getting all the slack on the adjuster side?
  2. Neville Lush
    Neville Lush www.nevillelushracing.com
    Country:
    Australia
    809
    Featured Threads:
    7
    2,167
    203
    Victor Harbor South Australia
    Ride:
    Speed Triple 1050 Dirt Track sidecar,H2750Roadrace sidecar W800 Kawasaki
    How many kms on the engine? Cam chain may be worn out and adjuster run out.
    Joesmoe and Tripps like this.
  3. R-III-R Turbo
    R-III-R Turbo Mine is the biggest :)
    1,426
    Featured Threads:
    29
    Media:
    87
    2,497
    223
    Ireland
    Ride:
    2.5L Stroker Rocket III, 04 Hayabusa
    As nev says do the tensioner drop and chain length measurements. In the manual, but you can use a calipers instead of the Triumph tool for the drop. 16mm is the limit before spacer is needed.
    Also you might have a watch of this, you might spot something useful
  4. warp9.9
    warp9.9 Pocałuj mnie w dupę
    10,328
    Featured Threads:
    9
    Media:
    14
    12,560
    823
    Forest City Illinois
    Ride:
    07 Rocket
    Im sorry to bud in and of course check the tensioner drop. Anyway are you using the timing fixture ? I ask because I do not see it. And going by eye with a straight blade across the head is not the way. Anyway one of the moderators still has my timing fixture. If you want we can get it mailed to you? Then when you're done one you can ship it back to me.
  5. GaryB
    GaryB .020 Over
    Country:
    United States
    11
    1
    3
    Chandler, AZ
    Ride:
    2005 Rocket III
    Thanks for the video it did give me some ideas to try.
  6. GaryB
    GaryB .020 Over
    Country:
    United States
    11
    1
    3
    Chandler, AZ
    Ride:
    2005 Rocket III
    I will do the tensioner drop just to make sure I don't need a spacer. I built my own timing fixture which seems to be working but maybe getting the official tool would be helpful. Who should I contact and give my address to?
  7. GaryB
    GaryB .020 Over
    Country:
    United States
    11
    1
    3
    Chandler, AZ
    Ride:
    2005 Rocket III
    Bike has 60,000 miles and the adjuster has at least 5 notches left on it. I will check all of that and confirm.
  8. GaryB
    GaryB .020 Over
    Country:
    United States
    11
    1
    3
    Chandler, AZ
    Ride:
    2005 Rocket III
    Thanks all for the help. I will hopefully get the checks done tonight and post the results. I also have some things to try since it occurs to me that I am either one tooth off on the crankshaft or the chain is worn out. The bike was running great before adjusting the valve clearances so I don't think the chain or tensioner is the issue but who knows.
  9. warp9.9
    10,328
    Featured Threads:
    9
    Media:
    14
    12,560
    823
    Ride:
    07 Rocket
    Paul aka
    @Joesmoe would be the man ! Now that he has been summoned he will pop in before long.
    phar2slo likes this.
  10. breeze
    breeze Living Legend
    Country:
    United States
    2,968
    Featured Threads:
    9
    4,257
    823
    bloomfield n.m.
    Ride:
    07 classic/01legend/72 bonne
    Tripps and GaryB like this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
